Observer tinghao780609
10G/25G Ethernet Subsystem can't link up
HI all
I used the 10G/25G Ethernet Subsystem to implement my design.  The IP configuration is present in this picture.
When i test this design, the ILA shown the rx_block_lock didn't assert and the rx_gt_lock was high , the other hand switch seem didn't link up .
How can i fix this issue?
Re: 10G/25G Ethernet Subsystem can't link up
If the positive and negative signals of a differential pair are swapped, then data cannot be correctly received on that lane.
Verify that the link has the correct polarity of each differential pair.
Did you check with loopback test before connecting to link partner?
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
Visitor leongnrl
Do you have the reference clock configured correctly? How do you configure your reference clock.
