10G BASE-R or 10G BASE-KR for 40G QSFP+ CU DAC cable from 10G/25G ethernet subsystem ip?
i have a 1m copper DAC cable .
should i select 10G BASE-R or 10G BASE-KR for the cable?
https://www.fs.com/products/30884.html
Re: 10G BASE-R or 10G BASE-KR for 40G QSFP+ CU DAC cable from 10G/25G ethernet subsystem ip?
Hi @m006
10G BASE-R supports data stream between board interface(SFP cable).
10G BASE-KR supports data stream across a backplane
Pratap
"Don't forget to reply, kudo and accept as solution."
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
so, which one should i select between QSFP1 and QSFP2 interface of VCU118 board for the 40G QSFP+ CU DAC cable ?
Hi @m006
You can select either of the QSFP interface, make sure GT selection and configuration matching with QSFP1/QSFP2 while configuring the IP
Pratap
Pratap
i should select  Base-R or Base-KR inside IP GUI  for the copper cable?
BASE-KR enables FEC and AN.  If you don't need these, then you can just use BASE-R.
but,the cable is copper,not optical.
Participant 140591x
Is that the only difference? will base-kr work with a dirrect attached copper(dac) cable????
