joe306
10G Ethernet IP for Zynq Ultrascale+ MPSoC
Hello, I need some help finding an IP that support 10G Ethernet for a Zynq Ultrascale+ MPSoc. I am planning on using the XZCU7CG-1FFVC1517I. I need to interface with a Fiber Optic Transceiver.
Which IP should I try:
Thank you
joe306
Hello, I've been looking over the two IP's and the 10G/25G Ethernet Subsystem seems to be the IP I'm looking to implement 10G Ethernet. I do have a question about what is PCS an PMA? Also, how do I choose the Core?
I would think that I would need a MAC but not sure if I need 32-bit or 64-bit.
Can you help me understand the different cores?
Thank you
joe306
I should say that I have a full license for Vivado/Vitis, so hopefully I won't need to purchase any IP.
Thank you
joe306
I'm looking at:
10 Gigabit Ethernet PCS/PMA (10GBASE-R)
https://www.xilinx.com/products/intellectual-property/10gbase-r.html
I'm not familiar with PCS or PMA, but I'll learn soon.
Thank you
joe306
Oops, that one is not available.
I'm looking at 1G/10G/25G Switching Ethernet Subsystem v2.5. Maybe that will be the one I need.
shabbirk
Hi @joe306
To know about the IP licensing refer to the individual IP product guides (10g/25g) and switching IP (1g/10g/25g) respectively. It needs license
https://www.xilinx.com/support/documentation/ip_documentation/xxv_ethernet/v3_2/pg210-25g-ethernet.pdf#page=11
https://www.xilinx.com/support/documentation/ip_documentation/ethernet_1_10_25g/v2_3/pg292-ethernet-1-10-25g.pdf#page=7
Best Regards
Shabbir
joe306
Hello, thank you for responding to my message. Which IP do I need?
joe306
What's is the big difference between the two IP's? What is a Switching System?
Thank you
joe306
Thank you
