09-20-2016 06:55 AM
Are there any settings I need to do for the PCS/PMA to support 10GBASE-SR? I am seeing bit errors with some SR SFP+s that don't seem to occur with LR SFP+s. Initially, I thought I needed to set the pma_pmd_type port to "111". However, with this setting the bit errors persist. Looking at the synthesized schematic in Vivado I see that the pma_pmd_type port only connects to the status register (makes no changes to GTH setting, etc.).
Details:
Tools: Vivado 2015.2
IP: 10G Ethernet PCS/PMA v6.0
FPGA: Kintex Ultrascale (xcku115-flvf1924-2-e)
I appreciate your help on this.
10-05-2016 05:17 PM
Thanks for the insight of all who responded. I now have all the SFPs running error free both with IBERT and in my system level bit error test. The final solution can in 4 parts.
09-21-2016 10:04 AM
The core by default uses DFE for Equalization, try changing to LPM and test it.
Generate the gtwizard design with LPM for 10GBASE_R protocol, compare the gr wrapper changes and replace in the design.
09-25-2016 10:03 PM
Allan
09-27-2016 10:13 AM
Thanks for the replies.
Using the IBERT I have been able to significantly improve the BER of the SFPs. By making adjustments to TX and RX settings, I have gotten them to the point of running for hours with zero errors in the IBERT. However, I still get some bit errors in my packet data related test with PCS/PMA. This might just be "the way it goes" since recent tests suggest I may be near the BER spec of the SFP, but I'm still investigating to make sure I get the best results I can.
I'll do another update to this thread when we've settled on our solution.
09-27-2016 06:18 PM
apogeedbkxilinx wrote: recent tests suggest I may be near the BER spec of the SFP
My experience has been that provided that the fibre is clean and undamaged and the optical signal level is well above the minimum (yet still below the maximum) specified for the SFP, the error rate will be much better than the BER spec of the SFP. On my boards I measure zero errors, even over the 10km or 40km test links that I keep next to my desk (they're surprisingly small).
10-05-2016 05:17 PM
