10G ethernet subsystem on zcu106
I've some problems with petalinux boot, I get some warnings and errors:
xilinx_axienet a0041000.ethernet: missing/invalid xlnx,addrwidth property, using default
xilinx_axienet a0041000.ethernet: couldn't find phy i/f
and when the eth0 goes up I get these errors:
xilinx_axienet a0041000.ethernet eth0: __axienet_device_reset: DMA reset timeout!
xilinx_axienet a0041000.ethernet eth0: XXV MAC block lock not complete! Cross-check the MAC ref clock configuration
The gt ref clock is 156.25MHz and in the system-user I set the mac address for the eth:
&xxv_ethernet_0 {
	local-mac-address = [00 0a 35 00 00 00];
I don't know if it's a petalinux configuration problem or a design error.
Re: 10G ethernet subsystem on zcu106
Hello andrea@ross
Why don't you try using the ZCU106 boot image below?
Zynq Release
Thank you
Yoichi
This forum is based on the cooperation of everyone who participates.
Kindly note - Please mark the Answer as "Accept as solution" if information provided is helpful.
Hi, @katsuki
I fixed the error (it was a design mistake)
 but now at boot I get a kernel panic:
Configuring network interfaces... [    8.217270] Internal error: synchronous external abort: 96000010 [#1] SMP
[    8.224044] Modules linked in: al5d(O) al5e(O) allegro(O) xlnx_vcu_clk xlnx_vcu xilinx_hdmi_rx(O) xlnx_vcu_core xilinx_vphy(O) video(O) mali(O) uio_pdrv_genirq
[    8.238310] CPU: 0 PID: 2548 Comm: ip Tainted: G           O      4.19.0-xilinx-v2019.1 #1
[    8.246562] Hardware name: ZynqMP ZCU106 RevA (DT)
[    8.251338] pstate: 60000005 (nZCv daif -PAN -UAO)
[    8.256118] pc : axienet_device_reset+0x258/0x2e0
[    8.260809] lr : axienet_open+0x2ec/0x598
[    8.264800] sp : ffffff8010cbb210
[    8.268099] x29: ffffff8010cbb210 x28: ffffffc879d07d00
[    8.273403] x27: ffffff8010cbb830 x26: ffffff8010cbbaf0
[    8.278707] x25: ffffff8008be0858 x24: 0000000000000000
[    8.284002] x23: 0000000000000002 x22: ffffffc87a4e6048
[    8.289298] x21: ffffff8008be0858 x20: ffffffc87a4e6000
[    8.294593] x19: ffffffc87a4e67c0 x18: 0000000000000000
[    8.299888] x17: 0000000000000003 x16: 0000000000000000
[    8.305183] x15: 0000000000000000 x14: 0000000000000000
[    8.310479] x13: 0000000000000000 x12: 0000000000000000
[    8.315774] x11: 0000000000000000 x10: 0000000000000000
[    8.321069] x9 : 0000000000000000 x8 : ffffff8010cbb9d0
[    8.326365] x7 : 0000000000000000 x6 : 0000000000000000
[    8.331660] x5 : ffffff8010cbb9d0 x4 : 0000000000000000
[    8.336955] x3 : ffffff800898ab18 x2 : 0000000000000000
[    8.342251] x1 : ffffff8008035000 x0 : 0000000000000003
[    8.347548] Process ip (pid: 2548, stack limit = 0x(____ptrval____))
[    8.353883] Call trace:
[    8.356316]  axienet_device_reset+0x258/0x2e0
[    8.360656]  axienet_open+0x2ec/0x598
[    8.364303]  __dev_open+0xd4/0x150
[    8.367697]  __dev_change_flags+0x154/0x1b8
[    8.371863]  dev_change_flags+0x20/0x60
[    8.375684]  do_setlink+0x288/0xb90
[    8.379164]  rtnl_newlink+0x3d8/0x6b0
[    8.382810]  rtnetlink_rcv_msg+0x218/0x300
[    8.386891]  netlink_rcv_skb+0x58/0x118
[    8.390709]  rtnetlink_rcv+0x14/0x20
[    8.394269]  netlink_unicast+0x1c4/0x258
[    8.398175]  netlink_sendmsg+0x164/0x338
[    8.402081]  sock_sendmsg+0x18/0x30
[    8.405553]  ___sys_sendmsg+0x268/0x2a0
[    8.409373]  __sys_sendmsg+0x68/0xb8
[    8.412932]  __arm64_sys_sendmsg+0x20/0x28
[    8.417014]  el0_svc_common+0x84/0xd8
[    8.420667]  el0_svc_handler+0x68/0x80
[    8.424400]  el0_svc+0x8/0xc
[    8.427266] Code: d2800060 9411a785 17fffff5 f9401261 (b9400020)
[    8.433350] ---[ end trace ba28dd59009edade ]---
Hi andrea@ross
I'm afraid, I don't know anything about your design.
To get to the cause,
1. Make a simple and easy design and make sure it works
2. Check the operation while adding the functions you need to the above design little by little
then,  you can narrow down the cause.
Yoichi
I solved the problem rebuilding the petalinux project. The link is up, but when I try to send some packets or to ping the zcu106 from the pc the ping fails, the zcu is not reachable or the ps doesn't receive the packet.sfp.JPG
Hello andrea@ross
Are the IP address of the ZCU106 Ethernet and your PC correct? Are they the same subnet mask?
Thank you
Yoichi
Hi @katsuki ,
yes, the pc and the zcu106 are in the same network and the addresses are correct, but after some tests I get the kernel panic again. I don't know why.
Andrea
Hello andrea@ross
Can you narrow down the cause?
What should you do to narrow down the cause?
Thank you
Yoichi
Hello, @katsuki
I can't narrow down the cause, because from the previous version I never change anythings, only some setting of the 10g/25 ip. I tried to use a previus version where there was no kernel panic error, but now also with that version appears the kernel panic.I tried to create a new petalinux project, but it continues to do kernel panic. Now I'm trying to create a new design project.
From the kernel panic stack it seems that the error occurs when the driver does axienet_device_reset
Hello andrea@ross
Is the previous version of the design a Xilinx example or your own?
Are the Vivado versions the same?
Are the versions of Vivado and Petalinux the same?
What is the difference from the previous version?
What did you change in the IP settings?
Thank you
Yoichi
The previous version is my design, the vivado version is the same 2019.1 and petalinux 2019.1. From the previus design I chanegd only the axi_lite clk of the ip and the GT lane from X0Y8 to X0Y10 (maybe this is the correct). I attach the design below.
Thank you,
Andrea
Hello andrea@ross
What if you only change the axi_lite_clk for the previous version that is running?
What if you only change the GT lane for the previous version that is running?
Thank you
Yoichi
If I change the GT lane, the error persist, in the previous version the axi_lite was connected to the wrong clock and I couldn't read the registers correctly.
"good" news, after some rebuild of petalinux I resolved the kernel panic, but now I get the error
Configuring network interfaces... [   10.861519] xilinx_axienet a0042000.ethernet eth0: __axienet_device_reset: DMA reset timeout!
[   10.871488] xilinx_axienet a0042000.ethernet eth0: __axienet_device_reset: DMA reset timeout!
[   10.881755] xilinx_axienet a0042000.ethernet eth0: XXV MAC block lock not complete! Cross-check the MAC ref clock configuration
with the scui I checked the si570 user clock and is configured correctly (156.25MHz).eth.JPG
Thank you,
Andrea
I managed to make it work, the only thing I can't make work correctly is the si570 clock. During the boot I find this:
[    5.388165] i2c i2c-1: Added multiplexed i2c bus 7
[    5.393146] i2c i2c-1: Added multiplexed i2c bus 8
[    5.411999] si570 9-005d: registered, current frequency 156250000 Hz
[    5.418375] i2c i2c-1: Added multiplexed i2c bus 9
[    5.425154] si570 10-005d: registered, current frequency 156250000 Hz
[    5.431620] i2c i2c-1: Added multiplexed i2c bus 10
[    5.436685] si5324 11-0069: si5328 probed
[    5.501122] si5324 11-0069: si5328 probe successful
Seems the chip is configured correctly, but at the end of the boot I get this error:
if I use the zcu106 scui I read the correct clocks
but only after I set (from the scui) the user clock to 156.25MHz the system start working.
Hello andrea@ross
If the output clock frequency of si570 is different from the expected value, it may be better to check the device tree.
Thank you
Yoichi
Hello @katsuki
From the petalinux boot seems that the os change the frequency, inside system-user.dts I put this lines:
&i2c1{
	status = "okay";
	i2c-mux@74 {
		i2c@2 {
			si570_1: clock-generator@5d { /* USER SI570 - u42 */
				factory-fout = <300000000>;
				clock-frequency = <156250000>;
				clock-output-names = "si570_user";
		i2c@3 {
			si570_2: clock-generator@5d { /* USER MGT SI570 - u56 */
				factory-fout = <156250000>;
				clock-output-names = "si570_mgt";
		i2c@4 {
			si5328: clock-generator@69 {
				compatible = "silabs,si5328";
It seems working, because I see from the boot that the frequencies are correct, but it seems that they are not applied.
Andrea
