10G ethernet subsystem reset pins are confuse
Hi, I'm trying to use the 10G ethernet subsystem on my VC707 board but I don't know how to properly connect the following pins :
  1. tx_axis_aresetn : I've connected to mm2s_prmy_reset_out of AXI2S FIFO(I think it's right)
  2. rx_axis_arestn: I've connected to s2mms_prmy_reset_out of AXI2S FIFO(I also think it's right)
  3. s_axi_aresetn: I've connected to peripheral_aresetn of my design(as I did for the others IPs, so I think it's right)
  4. reset: I've no idea about where connect it
Reading the datasheet of the IP, I found :
The reset input provides an active-High global asynchronous reset input that resets
everything in the design, including the transceiver and associated PLLs.
Each of the interface resets (s_axi_aresetn, tx_axis_aresetn, and
rx_axis_aresetn), apply local resets to sub-blocks of the overall design. These resets
should not be required in normal operation or implementation.
But I still don't know how to use that port(reset)
Hi @jamellyf
Reset is active high global asynchronous reset, this port can be connected to system reset, for example you can conncet to push bottom.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
Hey, @rpr can I connect it to the peripheral_reset[0:0] port of the Processor System Reset IP?
