Observer mtn3325
1G/2.5G PCS/PMA with an optical SFP
I have a question about the 1G/2.5G PCS/PMA core in BASE-X configuration.
In full duplex mode, does the core handle 1Gbps in each direction simultaneously when using with fiber optic media via SFP?
Michael
Re: 1G/2.5G PCS/PMA with an optical SFP
If the core is following the standard, which I assume it is, then it should handle 1 Gbps in each direction simultaneously.
Observer mtn3325
Thank you!
