1G Ethernet PCS/PMA SGMII V15.2 mmcm won't lock
Hello Xilinx world,
I am trying to port a functionning design from Vivado 2014.3 to vivado 2016.2.
This design uses gig_ethernet_pcs_pma inside a block design and work perfectly on target using vivado 2014.3 (pcs_pma v14.3).
But when using Vivado 2016.2 (pcs_pma v15.2), the signal mmcm_locked_out from gig_ethernet_pcs_pma refuses to go high...
Here is the waveform from the simulation:
I am using: no auto negocation, SGMII with transceivers, shared logic is included, no MDIO, i am feedding the IP with a 125 Mhz gtrefclk, and i am holding reset high while 200 Mhz independent_clock_bufg is not stable.
Is that a reset issue?
Mlefrevre
Re: 1G Ethernet PCS/PMA SGMII V15.2 mmcm won't lock
Please set the Example_Simulation generic before generating the output products to speed up the simulation.
The EXAMPLE_SIMULATION generic is provided in all modes to reduce simulation time.
In simulation, the value of EXAMPLE_SIMULATION should be 1. In implementation, the value of EXAMPLE_SIMULATION should be 0. To change the EXAMPLE_SIMULATION attribute you need to use the following command before the generation of the output products: set_property CONFIG.EXAMPLE_SIMULATION {1} [get_ips <component_name>]
IMPORTANT: EXAMPLE_SIMULATION generic should be set to 1 only for simulation; for synthesis this should be reset to 0.
If the Example_Simulation paremeter is not set then the initialization of the transceiver takes longer times and it holds the MMMC and output generation of the clocks takes upto 3ms. With the generic set you can see the clocks before 10us
Satish
check this ARs
http://www.xilinx.com/support/answers/58020.html
Thanks and Regards
Balkrishan
Thank you for the reply :)
But according to  http://www.xilinx.com/support/answers/54667.html this issue was resolved in vivado v14.1.
I have a functionning design using vivado 2014.3.
The mmcm won't lock when using vivado 2016.2.
Any idea?
Mlefevre.
The snapshot shows the simulation is not run enough time. Can you run it for more time and let us know if the issue persists?
If possible, log all the signals related to SGMII IP and share the log file.
The following signals can help to understand the issue to start with.
CPLLPD
CPLLRESET
CPLLLOCK
TXOUTCLK
GTTXRESET
Satish
Hi ,
Thank you for the replies :)
I let the simulation running for more than 3 ms and it worked :). Thank you.
GT_RESET_DONE signal goes high after 3054 us, using vivado 2014.3 it goes high after 56 us...
Mlefevre
