Observer umeshatop
2 set of AXI 1G/2.5 Ethernet Subsytem with SGMII interface enabled
I'm new to usage of transcievers. I'm using 2 sets of AXI 1G/2.5G Ethernet Subsytem with SGMII interface enabled on both EMAC Ports. I'm getting the Error as attached in the snapshot. I have also shared the the block design and pinout details,for your reference. I'm using Xilinx device xc7z015clg485-1.
It would be great, If somebody could share the user guide to use multiple EMAC with SGMII interface enabled.
Re: 2 set of AXI 1G/2.5 Ethernet Subsytem with SGMII interface enabled
Hey @umeshatop,
That part only has the one GT quad, so you'll have to use the shared logic for one of the cores. For one of the IP, can you go to the shared logic tab and change the option to "include shared logic in example design"?
Nicholas Moellers
Xilinx Worldwide Technical Support
Hey @umeshatop,
Nicholas Moellers
Observer umeshatop
Thanks! Its working. I'm now able to generate for 4 EMAC's also.
Hi @umeshatop ,
As it's working now, can you please mark the relavent post as "Accepted Solution" so it will benifit other users? Thank you!
"Don't forget to reply, kudo and accept as solution."
Observer umeshatop
Yes. I have marked it as Accepted solution.
