ale11286
AXI 1G/2.5G Ethernet Subsystem 7.1 (Transceiver Options)
Hi all,
I'd like to add AXI 1G/2.5G Ethernet Subsystem (7.1) IP in my design.
To make it simple, I decided to start from a xilinx example design with the IP configured for 1000BASE-X routed to the SFP cage on SFP0 for use on a ZCU102 board. This situation is very similar to mine.
In the example design Physical Interface Tab is like this:
Now, when I try to set Ethernet Speed and GT Reference Clock Frequency MHz, I can't do it, since the corresponding tabs are respectively gray and not present.
I suppose this difference (between my design and the example design which I started from) could depend on the different device used: I use xc7z015clg485-1, while the example uses xczu9eg-ffvb1156-2-e...
Or maybe, I need to enable/configure something else, like GTX..
Can you help me?
Thanks in advance,
Alessandra
Tags (2)
nanz
Hi @ale11286 ,
If you read PG138, you will see 2.5G speed support as below:
Support for 2.5G Ethernet. This feature is enabled for the following devices:
°Kintex®-7, Virtex®-7 with GTH and GTX transceivers
°Artix®-7 devices with GTP and speed grade -2, -2L, and -3
°UltraScale™, UltraScale+™ devices with GTH and GTY transceivers
°Versal ACAP with GTY transceivers
So the device you are using has GTP transceiver and you are having a -1 speed.
Also "GT reference clock" option is only available for US and US+ devices, so you won't see it when you create the project for Zynq.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
nanz
Hi @ale11286 ,
