AXI 1G/2.5G Ethernet example design on Spartan-7 SP701
What I want to do:
  • Run the AXI 1G/2.5G Ethernet Subsystem v7.1 (pg138-axi-ethernet.pdf) example design on Spartan-7 SP701
What I have done:
  • Open(ed) the IP Example Design (axi_ethernet_0_example) in Vivado
Questions:
  • What are the recommended next steps to get the example design running on the Spartan-7 SP701?
  • Is the Tri-Mode Ethernet MAC v9.0 (pg051-tri-mode-eth-mac.pdf) example design on Spartan-7 SP701 a better place to start?
Re: AXI 1G/2.5G Ethernet example design on Spartan-7 SP701
Hey @ziltoid_the_omniscient ,
For pin placement, check out the IO and Clock Planning hub, specifically UG899.
Nicholas Moellers
Xilinx Worldwide Technical Support
Spartan devices are only supported by ISE.  To my knowledge there is no easy way to take a Vivado IP and use it in ISE.  Starting with an ethernet design example that already exists in the ISE environment is your best bet.
Ted Booth - Tech. Lead FPGA Design Engineer
www.designlinxhs.com
Hi Ted,
Thank you for replying.
It looks like Spartan-7 devices are supported in Vivado. Can you please take a look at the following links I have provided?
Spartan-7 is not supported in ISE - https://forums.xilinx.com/t5/Other-FPGA-Architecture/do-ISE-14-7-supports-spartan-7/td-p/733236 - see balkris reply
Spartan-7 is supported in Vivado - https://www.xilinx.com/news/press/2017/xilinx-spartan-7-fpgas-now-in-production.html
Spartan-7 is supported device family for AXI 1G/2.5G Ethernet Subsystem v7.1 - https://www.xilinx.com/support/documentation/ip_documentation/axi_ethernet/v7_1/pg138-axi-ethernet.pdf - see page 4 (IP facts)
Ted, can you please take a look at the following questions again if Spartan-7 is supported?
Questions:
Hey @ziltoid_the_omniscient,
I would say if you've opened the Example Design, you probably want to simulate it next. You could also write it to bitstream, which might require placing some pins. We might be able to be more specific about what your next steps should be if you could be more specific about your goals.
The AXI 1G/2.5G Ethernet Subsystem consists of both a Tri-Mode Ethernet Media Access Controller (TEMAC) and an Ethernet 1G/2.5G BASE-X PCS/PMA or SGMII IP block. I find the AXI ethernet subsystem to be easiest to use.
Nicholas Moellers
Hi @nmoeller , thank you for your answer.
Ok.
What is the process to place the pins?
Goal: send a UDP packet to Spartan-7 SP701 which is echoed back to the source.
Proposed way to reach goal: Use loopback functionality MAC RX to TX from AXI ethernet subsystem v7.1 example design.
Thank you for confirming to use the AXI ethernet system over the TEMAC.
Nicholas Moellers
Thank you @nmoeller. I will read documentation.
