Observer jknoblau
AXI Data Width Convertor format
I have been trying to implement an AXI Data width convertor between 2 fifos in IP Integrator for interfaceing with a DDR3 module. I would like it to take in 16 x 32-bit samples and output 1 x 512bit sample in AXI format to be passed on to a DDR3 Module. I have tried many things including different aw / r cache and burst values but to no avail. There is fifo storage that should store the 32-bit samples until a 512-bit sample is full.
The closest i can get so far is a 32 to 512 bit conversion that writes a 32-bit sample to a 512-bit sample then increments the strobe signal. So I end up with 16 x 512-bit samples going into the DDR3 instead of just one.
While this does technically do a conversion it uses much more DDR3 memory than I would like and causes un-needed data path delays.
Is there anyone who could help me understand how this works better or if its possible to produce 1x 512-bit sample from 16 x 32-bit samples in an AXI Data Width Convertor?
Jon.
Re: AXI Data Width Convertor format
HI
Hope your issue is addressed here
http://forums.xilinx.com/t5/MIG-Memory-Interface-Generator/AXI-Data-Width-Converter-to-MIG-Module/m-p/464156#M6004
If not please let us know
Vanitha
HI
Vanitha
