sanchean
AXI EthernetLite -> Vitis errors with lwIP: "Failed to create application project" + No Ethernet MAC IP instance in the hardware
I'm trying to implement the following tutorial with an Arty A7 board (XC7A35TICSG324-1L device): Genesys 2 - Getting Started with Microblaze Servers [Digilent Documentation] (digilentinc.com). I'm also following XAPP1026 and this other tutorial: Arty Evaluation Board Tutorial LwIP Applications for the Arty Evaluation Board (avnet.com)
I'm trying to implement it without the microblaze data and instruction caches and without the access to the external Arty A7's DRAM.
This is my block diagram for the microblaze and axi interfaces (the top level just contains a clock generator and the wrapper of the block diagram):
On the Vivado side everything works fine: the write_bitstream process finishes correctly and the export of the .xsa file is correct.
On Vitis I can generate, compile and run without any issue the Hello World example application.
The problems arrive with the lwIP example applications:
  1. When I try to generate the lwIP Echo Server example application I get the following error:
    But the Vitis Log is not really helpful:
    14:13:42 INFO : Successfully done query RDI_DATADIR
    14:14:44 INFO : Result from executing command 'getProjects': top_arty_modbustcp
    14:14:44 INFO : Result from executing command 'getPlatforms':
    14:14:45 WARN : An unexpected exception occurred in the module 'platform project logging'
    14:14:47 INFO : Platform 'top_arty_modbustcp' is added to custom repositories.
    14:14:51 ERROR : Failed to call GENERATE_APP
    Reason: ERROR: [Common 17-39] 'hsi::generate_app' failed due to earlier errors.
    14:14:51 ERROR :
    java.lang.RuntimeException: Failed to call GENERATE_APP
    at com.xilinx.sdk.xsdb.XsdbCommandUtils.handleResult(XsdbCommandUtils.java:389)
    at com.xilinx.sdk.xsdb.XsdbCommandUtils.executeAndRespond(XsdbCommandUtils.java:327)
    at com.xilinx.sdx.sdk.core.gen.CTemplateGen.generate(CTemplateGen.java:105)
    at com.xilinx.sdx.sdk.core.gen.StandaloneProjectHandler.createCoreApp(StandaloneProjectHandler.java:93)
    at com.xilinx.sdx.sdk.core.gen.AppCreationHandler.createApplication(AppCreationHandler.java:79)
    at com.xilinx.sdx.sdk.core.gen.AppCreationHandler.execute(AppCreationHandler.java:69)
    at com.xilinx.sdx.sdk.core.SdkAppCreationHandler.executeInternal(SdkAppCreationHandler.java:75)
    14:14:51 ERROR : Failed to create application project
    org.eclipse.core.runtime.CoreException: Failed to call GENERATE_APP
    at com.xilinx.sdx.sdk.core.gen.StandaloneProjectHandler.createCoreApp(StandaloneProjectHandler.java:150)
    at com.xilinx.sdx.sdk.core.SdkAppCreationHandler.lambda$1(SdkAppCreationHandler.java:67)
    at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2292)
    at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2312)
  2. When I select any other lwIP example, Vitis complains that there is no Ethernet MAC IP instance in the hardware:
I'm a bit stuck... Am I overlooking something?
Cheers,
Andrés
nanz
Hi @sanchean ,
Please see attached the patches fixing the lwip performance apps build failures on both standalone and freertos.
Please note that Emaclite is an IP in maintenance and benchmarking perf numbers on slow MB designs is not in plan now. So these patches come with the disclaimer about numbers. We are also updated the wiki page to indicate the same.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
nanz
Hi @sanchean ,
We used to have an known issue:
https://www.xilinx.com/support/answers/71330.html
It looks like some regression between lwip and emaclite IP. I can double check.
In the meantime, could you please check the emaclite driver example and see if this works fine. Please check the below page - "Test Cases".
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842430/Emaclite+Standalone+Driver
sanchean
Thanks a lot for the answer! I will try to find some time this week to test these ideas.
Cheers,
Andrés
sanchean
Hi @nanz ,
I had some time yesterday to test the emaclite drivers examples... some of them work and some of them don't:
  • selftest_example.c: works fine
  • internal_loopback_example.c: gets stuck in function XEmacLite_EnableLoopBack(EmacLiteInstPtr);
  • phy_loopback_example.c: never ends
  • ping_req_example.c: as far as i know generates the pings, I see the orange led flashing on the ethernet connector, but I cannot reach any device. I tried 2 different setups:
    • arty -> ethernet crossover cable -> computer. Both IP addresses are set in the same subnet
    • arty -> ethernet crossover cable -> arduino with ethernet shield. Both IP addresses are in the same subnet.
    • for reference, when I connect the arduino to the computer with the same cable and I ping it, I get a response.
  • ping_reply_example.c: same stuff, example compiles and runs but the arty is not reachable, neither by the arduino nor by the computer.
Generation of the lwIP example with Vitis keeps crashing and the message about the missing Ethernet MAC IP is still there...
Andrés
nanz
Hi @sanchean ,
Do you have the XCI file that you can share? I will test this on my end too.
sanchean
Hi @nanz ,
You can find attached the ip core .xci file.
many thanks for your help!
andrés
nanz
Hi @sanchean ,
Can you please also share your XSA file? Thank you!
sanchean
Hi @nanz ,
There you go.
thanks again!
nanz
Hi @sanchean ,
Thank you for the files. I have reproduced the issue on my end and will check a bit more to confirm if this is a bug. I will come back to it.
nanz
Hi @sanchean ,
It seems it's a bug. I  just created a change request against the issue.
nanz
Hi @sanchean ,
I had a quick update on it.
This issue (ERROR: [Common 17-39] ) is observed because the lwip echo example has a memory constraint of (stack 40k and heap 40k). Can you please check that if your memory requirement meets this to build the examples?
sanchean
Hi @nanz ,
I just tried this solution and it works, now I am able to generate the lwIP Echo Server example. To do so I had to increase in the Vivado Address Editor the range of the /mb_local_mem/lmb_bram_if_cntlr_1/SLMB and the  /mb_local_mem/lmb_bram_if_cntlr_0/SLMB to 128K.
However, I can't generate the other examples (lwIP TCP Perf Client, lwIP TCP Perf Server, lwIP UDP Perf Client, lwIP UDP Perf Server) as Vitis still complains that there is no Ethernet MAC IP instance in the hardware.
nanz
Hi @sanchean ,
Good news! Thanks for the updates.
For the perf examples, it will need some more time to fix and test. Can you live with the lwip echo example for now and we will come with a solution for perf examples later?
sanchean
Hi @nanz ,
No worries, sure I do.
I don't really need those examples, I was just worried about the Vitis message about the missing IP.
For the moment I just generated the lwIP example. I will try it with the board these days and let you know how it goes.
Thanks a lot for all your help,
Andrés
nanz
Hi @sanchean ,
