oli669
Accessing Ethernet PHY from PL in the UltraZed-EV Starter Kit
I am migrating a design that includes a Tri-mode Ethernet MAC from a Series 7 FPGA in a custom PCB to a Zynq UltraScale+ in a UltraZed-EV Starter kit.
The documentation shows that the Ethernet PHY is connected to PS MIO of the Zynq. It is possible to access it from the PL in order to connect the TEMAC to the external PHY? If so, how? If not, is it possible to use the PS MAC controller from the PL with no SW intervention?
rpr
Hi @oli669
Seem that 7 series existing MAC is TEMAC, Zynq UltraScale+ also provides TEMAC(PL) use can use it.
Procedure is similar as 7 series.
Zynq UltraScale+ provides extra MAC i.e. Hard MAC(PS).
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
