Aurora 8b10b compatibility for V6 and KU implementations
Could anyone tell about compatibility of Aurora 8b10b  for V6 and KU implementations.
There are some potential issue: different Aurora IP versions, different implement tools (ISE14.7 vs Vivado 16), different MGT transievers etc. Is any way to make its compatible?
Re: Aurora 8b10b compatibility for V6 and KU implementations
The code updates you mention were done to match with GT user guide. In the older document, they protocol spec was not matching the GT user guide.
P.S. It seems, specification 2.2 (V6@ISE) and 2.3 (V7+@VIVADO) has different 8b10b coding table:
table A-1 Spec2.2:
D5.0 000 00101 101001 1011 101001 0100
table A-1 Spec2.3:
D5.0 000 00101 101001 1011 101011 0100
etc, totally 24 changed symbols.
Spec2.2  and Spec2.3 is not compatible?
