Newbie szorzetti
Aurora Latency
I am using the Aurora IP 64B/66B v7.3.
According to the manual the maximum latency for GTX trancevers is 37 USER_CLK. I have done the simulation suggested in the chapter 6 of the same manual, I have simulated the _exdes esample, and the related test bench, the result that I get is 50 USER_CLK, as you can see on the attached picture.
Do you have any idea why on the simulationI don't get the same result of the manual?
Thank you,
Silvia
Re: Aurora Latency
Kindly check the latest user guide, it is mentioned 53 clock cycles latency for simulation, page 11
http://www.xilinx.com/support/documentation/ip_documentation/aurora_64b66b/v9_2/pg074-aurora-64b66b.pdf
--Krishna
Re: Aurora Latency
The latency value specified in the documentation is for the default configuration. If any additional blocks (Ex: CRC) are enabled, latency could increase.
