Aurora_Single Mode SFP selection in KINTEX KC705
I am using a SFP [EOLS-PX-GU-20] which has different data rates:2.48832Gbps upstream and 9.95328Gbps downstream. Is their any possibility to use that SFP in KINTEX KC705.
Re: Aurora_Single Mode SFP selection in KINTEX KC705
What is your design target line rates? With Aurora, you will need to have Tx and Rx to be at same line rate.
In Kintex KC705, I need to use different data rates:2.48832Gbps upstream and 9.95328Gbps downstream in Aurora Protocol. Is it possible or not ?
Aurora IP does not have the option to have Tx and Rx at different data rates. You use case will require adjusting the clocking and GT parameters for either upstream or downstream.
