Aurora loopback between two transceivers in the same tile ML507
I am trying to implement an Aurora link between the two transceivers in the X0Y3 tile of the ML507 (XC5VFX70T) board. I am trying to complete a loopback test over a SATA link. How many Aurora cores would I need to generate? My understanding is that each Aurora lane/channel uses one transceiver so I would be needing two separate Aurora cores. I am not sure how i would combine them in a single project. Any help is appreciated.
Re: Aurora loopback between two transceivers in the same tile ML507
Yes. You will need to re-label signals of the individual cores on the top level and connect them at that level
Community Manager
Community Manager
If you are planning to have the same line rate and ref clk frequency for both the tiles, then you can generate a single aurora core with two lanes.
The following AR http://www.xilinx.com/support/answers/21263.htm also having useful knowledge related to your query
refer to Appendix A of ug353
http://www.xilinx.com/support/documentation/ip_documentation/aurora_8b10b/v5_3/aurora_8b10b_ug353.pdf
The issue here is that both transceivers are in the same tile so i can't just generate a core with 2 lanes.
Community Manager
Community Manager
You need to generate two cores and stitch them together (by manually editing) to make use of single dual tile.
Refer to the link provided by @venkata.
I have looked into that portion of the UG but I am not sure about how to implement the stiching of the two cores in one project. Do i have to re-label signals of the individual cores on the top level and connect them at that level? Any previous work that i can take pointers from?
hi,
I am doing the same thing with PCIE protocol. How can I write the UCF file for loop back testing and is there any jumper setting for loop back ?
can you create a different post in PCIe board?
My problem is wtih GTX & SATA . Anyways give me thread of PCIE
In the previous post you mentioned about PCIe. This is why I have told to create topic in PCIe board.
If it is between GTX and SATA, then create a new topic in this board itself.
