amarb27
Aurora loopback
I am trying to loopback the aurora just to debug,but i am not able to see any aurora packets transmitting.When i put chipscope and cheked it is because channel_up is not initialising and it depends on lane_up,so the whole process is interlinked so i can't change the core??
My IP version is 5.3,device spartan-6(LX45T-fgg484) and aurora lanes-2,lane width-4,clk-125MHz( my old version aurora lanes-2,lane width-2,clk-125MHz is working fine) i just want to change lane width.pls any one help
jordanki_bah
Give me some more info and I might be able to help.  Data rate?  Duplex or simplex?  8b/10b or 64b/66b?  When you chaged to x4, did you update your UCF with the additional clock constraints?
-Jordan
This signature intentionally left blank.
amarb27
Date rate -2Gbps,Duplex, 8b/10b
No i didnt update my UCF for additional clock constraints,should I??
venkata
Have you regenerated the core for the new data width?
Try with GT loopback to start with. Check with loopback = "010".
smarell
Community Manager
Community Manager
Why are you planning to change the lane_width and how are you doing it?
Did you simulate your design?
amarb27
Yes,i have generated a new Aurora core.I have checked with Loopback "010".
amarb27
Because at the Receiving end we need a 32bit data(4 byte),i changed the lane width in IP generation.
No i didn't simulate the design
jordanki_bah
Do you need the 4 byte width to meet specific timing or can you take the 2-byte output and just pass it through a grouping module to make it 4-bytes?
-Jordan
borisq
please try Aurora example design. it is a full design with ucf properly set.
