Axi ethernet Packet format
Hey. Tell me, what format do the data from the output (m_axis_rxd) of the axi-stream of the Axi-Etnernet ip have? What is the order of bytes and bits inside a byte? An example picture
Re: Axi ethernet Packet format
Looking further along the packet (the lengths is the biggest give away) , then Yes, it is variant B.
You still need to switch all the bytes around the make it easier to debug.
Hi @fincs ,
Have you tried to run the example desgin simulation? This is the best way to check the packets and get the info you are looking for.
To run example design simulaton, you will just need to generate the core in Vivado and right click ont the .xci and open the example design; and then click on run simulation.Hope this helps.
@fincs
Variant A.
Bytes are in network order packed in an annoying to debug way. So byte 0 is in [7..0]. So [7..0] is the MSBs of the dest mac address.
The first thing I usually do in my code flip all the bytes around so they make sense and readable on a wave window.
@richardhead @nanz Thanks.
Opened an example in the simulator.
Input MAC Value
assign mtrlb_config_dest_addr = 48'hDA0203040506 ;
assign mtrlb_config_src_addr = 48'hCA789BCDEF12 ;
Tx from pattern generator:
0x040302da
0x78ca0605
0x12efcd9b
The result is Variant B.
Hi @fincs ,
Could you please mark the relevant thread as "accepted solution"? So it will benifit other forum users. Thank you!
