Observer ilya.kalistru
CMAC PAUSE resend timer units
Hi all!
PG203 describes CTL_TX_PAUSE_REFRESH_TIMER as a time between pause frame retransmissions.
But it does not describe what units this value has. For example, if set
CTL_TX_PAUSE_REFRESH_TIMER8 = x"0005"
what exactly does it mean? 5 seconds? 5 microseconds? 5 quantas? 5 cycles of some clock?
Best regards,
Ilya
Re: CMAC PAUSE resend timer units
IEEE 802.3 (section 2) para 31B.2 says "The pause_time is measured in units of pause_quanta, equal to 512 bit times of the particular implementation ..."
I assume that those are the units that Xilinx uses on that interface, in the absence of any documentation to the contrary.
Allan
Yeah... Probably.
But I'd rather know for sure.
It would be great if some Xilinx employee responded and then fixed description of the port in the document.
Best regards,
Ilya
