Can Zynq IP/FIFO use in ISE spartan 3e project ? [work on 1588 ethernet IP for spartan 3e project]
would like to ask it is possible to use Zynq IP for the spartan 3e project?
I tried to load the IP /FIFO to my ISE 14.7 and hit the "Regenerate All Core" is able to regenerate the core, but when I set the UCF for spartan 3e and run implement Design, it gives the error :
ERROR:Pack:1107 - Pack was unable to combine the symbols listed below into a
single IOB component because the site type selected is not compatible. The
component type is determined by the types of logic and the properties and
configuration of the logic it contains. In this case an IO component of type
IOB was chosen because the IO contains symbols and/or properties consistent
with output or bi-directional usage and contains no other symbols or
properties that require a more specific IO component type. Please double
check that the types of logic elements and all of their relevant properties
and configuration options are compatible with the physical site type of the
constraint.
Summary:
Symbols involved:
BUF symbol "RD_DATA_COUNT_0_OBUF" (Output Signal = RD_DATA_COUNT<0>)
PAD symbol "RD_DATA_COUNT<0>" (Pad Signal = RD_DATA_COUNT<0>)
Component type involved: IOB
Site Location involved: V8
Site Type involved: DIFFSI
The IP that I refer from opencores : https://opencores.org/projects/ha1588
Anyone can help with this? I new to  Spartan 3e and also ISE.
the purpose of my project is to create communication between PC and spartan3e using the 1588 protocol
Thank you
Hi @ju.han.goh ,
Zynq PS IP is not supported on Spartan 3e.
Praveen
Hi @ju.han.goh ,
Praveen
Hi ,
@pvenugo noted.
I need to create my won FIFO or IP in order to fit in spartan 3e right?
could you share , where can i refer the details to create the FIFO on spartan 3e and guidance ?
1 would like to create and FIFO for 1588 protocol on spartan3e
Thank you
