Visitor dawang
Can a Quad of GTH in Ultrascale support 1G Ethernet and 10G Ethernet mixing mode at the same time?
Hi, there
I am trying to use all four GTHE4 transceivers within one Quad. Since each transceiver can support up to 16Gbps, I wonder if I can choose some number transceivers to work at 1G Ethernet, while others work at 10G Ethernet at the same time?
Thanks for the help.
David
回复: Can a Quad of GTH in Ultrascale support 1G Ethernet and 10G Ethernet mixing mode at the same time?
Hi @dawang,
This should be ok, and pg292/xapp1307 can help:
http://www.xilinx.com/support/documentation/ip_documentation/ethernet_1_10_25g/v2_2/pg292-ethernet-1-10-25g.pdf
http://www.xilinx.com/support/documentation/application_notes/xapp1307-1g-10g-switching.pdf
Simon
