Visitor stuifmeel
Can not find 40/50Gbps IP in the IP-catalog Vivado 2016.2
Two weeks ago I received an evaluation license for the Xilinx 40/50Gbps Ethernet IP.
Unfortunately even afer installing Vivado 2016.2, which should contain the IP in the IP-catalog,
I can not find it in there.
Meanwhile time is ticking on the expiration of my evaluation license.
My workstation is not connected to the intenet, perhaps that may be the problem.
There should be a way to obtain the IP and import it into the IP catalof though.
How can I obtain the 40/50Gbps evaluation IP?
How can I import it into the IP-catalog of Vivado 2016.2?
Re: Can not find 40/50Gbps IP in the IP-catalog Vivado 2016.2
Hi @stuifmeel,
After logging in into forums you should be able to see "Accept as solution" on the right side of the answer.
Arpan
Hi @stuifmeel,
Kindly check if you have selected the correct device. Below is the snapshot which lists the supported architectures. Also you can find this info in http://www.xilinx.com/products/intellectual-property/ef-di-50gemac.html
Can you please try with a project selecting KCU105 board?
Arpan
these IPs only supported through IPI. create block design and instantiate these blocks
Thanks and Regards
Balkrishan
Hi @stuifmeel,
Are you able to see the IP in IP catalog now or you are still facing this issue?
Arpan
Visitor stuifmeel
I had no idea that IP was being masked out because of device/board selection.
Where can I check the  "Accept as solution" option?
Cheers!
Hi @stuifmeel,
Arpan
