Changing Zynq Ultrascale+ GEM MAC Speed/Duplex After Starting MAC
If the MAC is already started with a default speed/duplex (1000Mbps/Full), is it necessary to stop the MAC before changing the speed/duplex bits in the GEM network_config register to match the PHY?  The PHY was initialized after starting the MAC.  What happens if the MAC is not stopped and re-started but the speed duplex bits are just changed?  Does the MAC keep running at the previous speed/duplex or switch to the new speed/duplex?
Tags (3)
Hi @cstreece ,
The changes won't take into effect if you do not re-start/config the core.
Hi @cstreece ,
Ok. Thanks
