joe306
Choosing 10G Ethernet IP
Hello, I'm using a Zynq Ultrascale+ MPSOC and need to implement a 10Gigabit Ethernet. Which IP is easier to use:
10G/25G High Speed
Ethernet Subsystem v3.2
1G/10G/25G Switching
Ethernet Subsystem
v2.3
Each IP look very similar.
Also, what is a "Switching" subsystem?
Thank you,
Joe
guozhenp
These IP cores support multiple speeds.
If you don't need to change the speed and only run 10G, you can use AXI 10G Ethernet Subsystem
https://www.xilinx.com/support/documentation/ip_documentation/axi_10g_ethernet/v3_1/pg157-axi-10g-ethernet.pdf
guozhenp
joe306
Hello, thank you very much for responding to my post.
Joe
