Visitor gt1524a
Compiling 2019.1 ERNIC IP source for Questa 10.7c sim
I have been able to compile the sim netlist for simulation and it works fine.  I'm trying to speed up the simulation that I am running by instead simulating the Verilog source.  I tried these commands within a makefile that I'm using:
	@vlog -work work +incdir+$(XILINX_PLATFORM_IP)/ernic_zcu102/hdl/common \
	 $(XILINX_PLATFORM_IP)/ernic_zcu102/simulation/blk_mem_gen_v8_4.v \
	 $(XILINX_PLATFORM_IP)/ernic_zcu102/simulation/fifo_generator_vlog_beh.v \
	 $(XILINX_PLATFORM_IP)/ernic_zcu102/hdl/fifo_generator_v13_2_rfs.v
	@vcom -2008 -bindAtCompile -work work \
	 $(XILINX_PLATFORM_IP)/ernic_zcu102/hdl/fifo_generator_v13_2_rfs.vhd \
	 $(XILINX_PLATFORM_IP)/ernic_zcu102/hdl/lib_bmg_v1_0_rfs.vhd \
	 $(XILINX_PLATFORM_IP)/ernic_zcu102/hdl/lib_fifo_v1_0_rfs.vhd
	 $(XILINX_PLATFORM_IP)/ernic_zcu102/hdl/fifo_generator_v13_2_rfs.v \
	 $(XILINX_PLATFORM_IP)/ernic_zcu102/hdl/ernic_v1_0_rfs.sv \
	 $(XILINX_PLATFORM_IP)/ernic_zcu102/sim/ernic_zcu102.sv
The commands complete successfully and I only get one warning while executing these commands, which I'll paste here:
** Warning: ../cores/ernic_zcu102/hdl/ernic_v1_0_rfs.sv(73): (vlog-2600) [RDGN] - Redundant digits in numeric literal.
When I launch my design in Questa, I get these errors that I'm unable to debug further because the encrypted source is limiting my visibility.
# ** Note: (vsim-3812) Design is being optimized...
# ** Error: ../cores/ernic/hdl/ernic_v1_0_rfs.sv(73): in protected region
# ** Error: ../cores/ernic/hdl/common/ernic_macros.vh(73): in protected region
# Optimization failed
# Error loading design
I am not a Verilog designer.  I'm hoping that either a Verilog user or a Xilinx expert can help me out.  Thanks for your time.
Re: Compiling 2019.1 ERNIC IP source for Questa 10.7c sim
Hey @gt1524a ,
You might try synthesizing the files before simulation, like in this post on the same topic.
In this post, they recommend using launch_simulation -scripts_only from Vivado to ensure the compile list and library references are correct.
Please give that a try and let us know how that works. Hope it helps!
Nicholas Moellers
Xilinx Worldwide Technical Support
Hey @gt1524a ,
Nicholas Moellers
Visitor gt1524a
I was able to modify the scripts generated with "launch_simulation -scripts_only" to support the build process I was attempting.  It runs much faster now.  Thank you!
