hagaya
Cortex M3 soft IP on ARTIX 7 using DesignStart
Does  the Cortex M3 soft IP supports ethernet ?
I know that the ST evb with ARM cortex M3 does support ethernet.
Tags (2)
vanmierlo
Mentor
Mentor
If you add an AXI Ethernet MAC it will. The AXI Ethernet Lite IP core seems to be a good fit.
