jcwill585
DHCP Timeout and unable to ping or telnet zynq 7020 running lwIP echo server on zturn board, server makes successful ARP requests
I run the lwip echo server on the zynq 7020 and I get a DHCP timeout error.  When I ping the default IP address of 192.168.1.10 I get either "Request timed out" or "Destination is unreachable" and telnet is unable to connect.  I connect directly to the rj45 on the zturn to my laptop and wireshark shows that the zynq broadcasts successful ARP requests from IP address 192.168.1.10 and the default mac address 00:0a:35:00:01:02.  What setting in TCP or anywhere may I change to get and send packets?  I'm in new territory working with ethernet, tcp, and server configurations.  Thanks for the help.
jcwill585
I made a new vivado project and connected a PL clock of 100 MHz to the GP M AXI CLK input.  Also I changed the autonegotiation to initialize the KSZ9031.  I still get DHCP Timeout but I am able to ping and telnet.
savula
Hi @jcwill585 ,
DHCP timeout is expected when the hardware is directly connected to system(Laptop). In this case, the ethernet port is assigned with static IP (192, 168, 1, 10) and you need to ping this address (I saw that you are doing the same, so no issue). I need know what Phy chip you were used in your hardware. I hope it is marvel phy chip, in case if it is not marvel phy chip then please go through the AR:  https://www.xilinx.com/support/answers/63495.html
If you are using Marvel phy chip then please change the below in LWIP BSP settings and check once:
MEM_SIZE 524288
MEMP_NUM_PBUF 1024
MEMP_NUM_TCP_SEG 1024
PBUF_POOL_SIZE 8192
N_RX_DESCRIPTORS = 512
N_TX_DESCRIPTORS = 512
TCP_SND_BUF 65535
TCP_WND 65535
Also change the phy link speed from auto negotiation to fixed speed (1000/100 Mbps) and test it.
Best Regards,
Srikanth
jcwill585
I have a Microchip PHY KSZ9031RNX: http://ww1.microchip.com/downloads/en/DeviceDoc/00002117F.pdf.  When I set the speed to 100 the program keeps cycling through "Ethernet link up" and "Ethernet link down".  Also I changed those TCP settings and I'm still not able to ping or telnet.
savula
Hi @jcwill585 ,
which version of vivado are you using? if it is 2018.2 then please migrate it to 2019.1 and check once. have you checked the AR that I have provided? as the phy chip is not marvel, you need to check once this AR: https://www.xilinx.com/support/answers/63495.html
Best Regards,
Srikanth
claytonr
Hey @jcwill585 ,
Have you configured your laptop to use a fixed IP address for the ethernet port that you've attached to the board? You'll need to set it to be on the same subnet as the board otherwise it won't believe there is a path to the address you're trying to reach.
The below examples are assuming the board is on the 192.168.1.x subnet (192.168.1.10).
In Windows you can do this using the network ipv4 settings:
On Linux you can change this using ifconfig:
Hope this helps!
Clayton
jcwill585
I'm using Vivado 2019.1 and yes I have checked the AR.  I'm able to get through the autonegotiate process.
jcwill585
Yes I'm on the same subnet.  I'm using IP 192.168.1.11.
jcwill585
jcwill585
What exactly do these settings do?
