eron
Data transfer from FPGA to PC with ethernet
I work on a ZC706 board. I want to send data from ZC706 to the PC by using ethernet (Because of i need fastly and big data throughput).
How can i do it? I want to use AXI 1G/2.5G Ethernet IP but i don't know how can i use it. Is there any example about it?
If i use AXI 1G/2.5G Ethernet IP, is DMA need to use it?
there any example that can help me to understand and implement my project?
Thank you very much,
Tags (3)
nanz
Hi @eron ,
You can refer to XAPP1082: https://www.xilinx.com/support/documentation/application_notes/xapp1082-zynq-eth.pdf
Or XAPP1026 as a starting point: https://www.xilinx.com/support/documentation/application_notes/xapp1026.pdf
If using AXI Ethernet, an DMA or AXI FIFO needs to be used. If using GEM, it has its dedicated DMA in PS.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
nanz
Hi @eron ,
eron
Thank you for reply my question. I tried your app suggestion xapp1082. it was very useful for me. I have an another question. How can connection my custom IP to AXI 1G/2.5G Ethernet Subsystem ip? Which port is usable? I want to try a counter example that my custom counter IP send data to Ethernet IP and then i will send my data to PC for controlled experience.
 Thank you.
nanz
Hi @eron ,
You can connect your custom IP to AXI stream interface (User interface) of AXI Ethernet Subsystem IP. You can look into the example design from Vivado (right click on AXI Ethernet IP, and click on open IP example design). Our packet generator is one of the examples.
