Diagram design for 100 G Ethernet using CMAC IP
please, can someone help me to build a design for 100 G Ethernet as in the figure below. I have a vcu108, I successfully  generate 100 G using CMAC IP example design, but this example design send a limited number of packets and stop which is an issue for me. I need to generate a continuous flow of packets, that is why I need to build my own design.
Thank you in advance.
  100G.gif:
 Thank you.
Scholar hbucher
Re: Diagram design for 100 G Ethernet using CMAC IP
@elidrissi  I am not familiar with this specific design but I am sure the Packet Generator has an option to control the quantity and type of packets created. Have you looked inside the implementation? Is that a hier or a Xilinx IP?
I didn't find any packet generator IP in Vivado. there is an axi_traffic_gen but its not compatible with cmac core.
Scholar hbucher
@elidrissi So you are still building the design if I understand? I thought you had the example design.
If you actually get the design, open it and look inside, you might have a better view of what is needed.
yes I have the example design it work well, inside it there is a packet generator connected to the Lbus transmitter.
Scholar hbucher
@elidrissi So what is this packet generator? Is it a verilog module or a design hier block?
 it s a verilog module
Scholar hbucher
@elidrissi Can you look at what it is doing? Is there any counter? Can you share?
Or that's not the point?
