Does PS-GTR support 1000BASE-X?
I was wondering if the 6 Gb/s PS-GTRs on the Zynq UltraScale+ can be configured as 1000BASE-X. The Zynq UltraScale+ TRM, UG1085, only mentions SGMII.
It is my understanding that 1000BASE-X and SGMII are pretty similar.
Re: Does PS-GTR support 1000BASE-X?
Hi @khal,
We do support PS-GTR with 1000BASE-X apart from SGMII.
We have updated UG1085 accordingly
"GEM supports the serial gigabit media-independent interface (SGMII, 1000BASE-SX, and 1000BASE-LX) at 1000Gb/s using the PS-GTR interface"
"Don't forget to reply, kudo and accept as solution."
Hi @khal,
Hi @nanz!
Do you mean that PS GTR in Zynq UltraScale+ support only Cisco SGMII specification and don't support 1000BASE-X Auto-Negotiation functionality defined in Clause 37 of the IEEE 802.3?
Hi @miloserdin,
Could you please post a new thread on this question so I could answer it from there? This one is from one year ago and old. I'll close it.
For future reference, it will be always good to start a new forum post rather than replying an old one. This way, you will have better chances to get help.
Thank you!
