Giorgian
Does the Xilinx ZCU102 Support RDMA?
Specifically, I am wondering whether I can use ERNIC/ERTNIC with it. I have found reference implementations for the U200 and the U250. Is there an implementation for the ZCU102?
crohrer
There is no existing ERNIC reference design for the ZCU102.
Also, while you can target the ZU9EG-2 part, the ERNIC natively communicates with the CMAC, which does not exist in that part. So, you would be required to build and test a different interface.
crohrer
