Chetan140
Dual Ethernet Port LWIP
We have a custom board that contains a zynq 7000 series FPGA and dual ethernet port with shared MDIO lines. We are able to use them individually in the Bare-metal LWIP application, but we need to use them both at the same time in LWIP. As per the documents, LWIP only supports one Eth port at a time, We need your help in achieving dual-port ethernet configuration and usage.
Chetan C A
nanz
Hi @Chetan140 ,
Could you please check the following thread and see if that helps?
https://forums.xilinx.com/t5/Processor-System-Design-and-AXI/Microblaze-dual-ethernet-problem-with-LWIP/m-p/968222#M45359
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
