06-27-2018 07:22 AM
Dear colleagues,
I am working in a project with a self-developed board that uses TI DP83867 PHY for ethernet comm. The SoC is a buy-in module from KnowRes that has a Zynq 7030 (xc7z030ffg676-1) device. The PHY is connected via MIO to EMAC0 and I run the Echo_Server application with lwip 1.8.
Though I can establish connection with the link partner and auto-negotiation has the correct result, my EMAC does not receive ANY packet.
Here is what I tried/measured/know:
- The RX signals out of the PHY (rxc, rd, rx_ctl) seem to be fine.
- I am able to transmit a packet to the link partner (the host PC receives the gratuitous ARP).
- All the phy registers seems ok.
- sclr_mio_pin_22 to 27 are configured as 0x1303.
- the EMAC statistics for the receiver stay in 0.
- I changed the rx clock delay from 0 to F (0ns to 4ns) and it had no effect.
- Two (long) days ago, it worked fine for a while.
Does anyone have a clue of what could be?
Thanks in advance,
Tomas
07-16-2018 02:46 PM - edited 07-16-2018 02:48 PM
Hi, colleagues,
I found at the end the reason for my problems and leave it here hoping it can be useful to someone. Well, the Texas PHY has a weak driver for the Rx signals, i.e., Rd(3:0), rx_ctl and rxc, specially with 1.8V VDDIO.The PCB + the Zynq input capacitance represents a heavy load and the rise and fall times are ~4µs, so the signals look like this:
RD0
RXC
As a solution, I will increase the supply voltage to 2.5V, because the drivers become stronger and hopefully it my solve my issue. If not, re-driving the PHY signals will be necessary.
Also, as a lesson learned, be advised that the MAC does not process a packet if the error signal from the PHY is asserted. It's obvious now, but it was hard for me to learn it.
Cheers,
Tomas
06-28-2018 03:26 AM
Here are the GEM0 statiscs registers. 0xEB000B158 is number of received packets.
And here the GEM0_RX_CLK enabled and the TX clock is correctly configured to 125MHz (1000Mbps):
07-04-2018 05:14 AM
Hi, everyone. This is a follow up post.
07-09-2018 07:13 AM
Hi @tpcorrea,
The Zynq GEMs do not add clock skew to the TX/ RX clock, therefore the skew must be added by the PHY or the PCB trace.
Hi, colleagues,
RD0
RXC
Cheers,
Tomas
