Error during loopback in the AXI Ethernet while using IP Integrator
I want to do the loopback in AXI ethernet at the MAC layer in ZCU102 Evaluation board. So, I am connecting the gmii_txd to gmii_rxd in IP Integrator as shown in  the screenshot. But when I am doing implementation then error is coming that Non IO buffer of gmii_txd can not be connected directly to IDATA pin of IDEALY in gmii_rxd.
I also tried to connect the gmii_txd to gmii_rxd through Utility buffer but then also same error was coming. '
So, is there any way to connect the gmii_txd pin of AXI Ethernet IP to its gmii_rxd pin so that loopback can be done at MAC layer. I don't want to use physical layer for this.
Scholar dpaul24
Re: Error during loopback in the AXI Ethernet while using IP Integrator
@shanish,
If you want to do a mac_loopback, then you must do it on the axis_*xd signal side . That would be a MAC side loopback.
As soon as you are talking about gmii_*xd you are already on the PHY side. A loopback of these signals is considered a PHY loopback.
FPGA enthusiast!
All PMs will be ignored
