xilinxuser1
Ethernet 10g AXI Interface - Simulation Errors
I have generated a 10g Ethernet core with AXI interface, and have found that during a simulation, internal Ethernet register read commands will return an 'X' (undefined). Reading the following registers will return an 'X':
STAT_RX_TOTAL_PACKETS_MSB (080C)
STAT_RX_TOTAL_PACKETS_LSB (0808)
STAT_RX_TOTAL_GOOD_PACKETS_MSB (
I am sure if I tried other registers I would get similar results.
I am using the following tool settings:
Xilinx UltraScale+ Zynq
Vivado 2019.1
Cadence Xcelium 20.03.005
Is there anything specifically that needs to be done to properly read Ethernet core registers using AXI interface?
Tony
nanz
Hi @xilinxuser1 ,
In your simulation, you see a successful linkup and packet transactions? Have you tried the example design simulation directly? Or in Vivado/Questa simulator to see if that works well?
I'd recommend starting with example design simulation and checking the waveform to compare the sequences.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
xilinxuser1
Yes, I can see successful packet transactions, only reading of the AXI interface registers shows undefined data.
I have tried the example design, and it was able to run correctly, but I do not recall seeing multiple AXI interface register read transactions. It would be ideal to have the example design run ethernet packets through the core, and read several ethernet registers, similar to ones I have listed in the original post.
nanz
Hi @xilinxuser1 ,
Can you please upload your simulation waveform so I could take a look? Thank you!
