aparna3103
Ethernet DMA
Now I am using Ethernet DMA application in vivado on Z7020 board.
By using example given in https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841971/Zynq-7000+AP+SoC+-+Performance+-+Ethernet+Packet+Inspection+-+Bare+Metal+-+Redirecting+Headers+to+PL+and+Cache+Tech+Tip link, data is coming. But this is the loopback test.
Now I want to send the data to Ethernet from PC. Can you please suggest me how to send the data?
Tags (2)
nanz
Hi @aparna3103 ,
So we have LWIP example codes available from Vitis which you can refer to. You just needed to create an application example in Vitis based on your .xsa file , and you will see lwip examples and can generate it and test it directly on HW.
You can also refer to github lwip examples:
https://github.com/Xilinx/embeddedsw/tree/master/ThirdParty/sw_services/lwip211/examples
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
aparna3103
Thank you for your reply.
But I don't want to use LWIP. I am using above mentioned application.
In that only MAC address is present. There is no IP address configuration in that.
Can we send the data using MAC address from PC to HW?
nanz
Hi @aparna3103 ,
You will need to assign IP address in order to communicate between the board and the PC.
