Visitor kishorep
Ethernet on custom 7030 board not working
Hello All,
  We are working on Zynq 7030 customized board with DP83867IR transceiver , where I am unable to ping custom board to/from other PC(in same network), But  able to ping in U-boot and  also able to get loopback response.
ifconfig output:
eth0      Link encap:Ethernet  HWaddr 00:0A:35:00:01:22
          inet addr:192.168.2.222  Bcast:192.168.3.255  Mask:255.255.252.0
          inet6 addr: fe80::20a:35ff:fe00:122/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:3096 dropped:0 overruns:0 frame:3096
          TX packets:15 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:1054 (1.0 KiB)
          Interrupt:29 Base address:0xc000
dts file configuration:
&gem1 {
    status = "okay";
    phy-mode = "rgmii-id";
    phy-handle = <&ethernet_phy>;
    pinctrl-names = "default";
    pinctrl-0 = <&pinctrl_gem1_default>;
    ethernet_phy: ethernet-phy@30 {
        reg = <30>;
                ti,rx-internal-delay = <0x8>;
                ti,tx-internal-delay = <0xa>;
                ti,fifo-depth = <0x1>;
        device_type = "ethernet-phy";
                ti,rxctrl-strap-worka;
If i tried to ping to other pc from my custom board following message come:
/ # ping 192.168.3.241
PING 192.168.3.241 (192.168.3.241): 56 data bytes
^C
--- 192.168.3.241 ping statistics ---
134 packets transmitted, 0 packets received, 100% packet loss
Is their any extra modification needed in the kernel to avoid RX packet loss
( RX packets:0 errors:3096 dropped:0 overruns:0 frame:3096)
please help me sort out this issue...
Kishore P
