Ethernet port vs Ethernet from SFP port of ZYNQ
what different between using Ethernet from SFP port(with converter) than Ethernet port of ZYNQ board?
Thanks to helping me in this case.
Re: Ethernet port vs Ethernet from SFP port of ZYNQ
Hi @adnan86
Xilinx provides both MAC and PHY.
If you are looking only MAC (GMII/RGMII/MII) then external on chip phy should interface to it and ethernet port is used.
Looking for both MAC and PHY (1000 base-x  GT transceiver) then SFP port is used.
Detailed information documented in PG051(MAC) and PG047(1000 base-x ).
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
Hi @adnan86
Pratap
Really thankful. I'm was looking for the reason for a while.
