Ethernet testing in OS enviroment through RJ45 connector
Hello everyone,
I am working on xilinx ZCU102 evaluation board and I have tested one of the ethernet test which is mentioned in document provided by Xilinx  "xtp431-zcu102-ipi"  PS Ethernet Test. In this test we have performed pinging from host machine to board and vice and versa in bare metal environment.
Now I would like to perform similar experiment in linux environment and I don't know how to perform that. Therefore any suggestion regarding this will be very helpful.
Thanks and Regards
Jaydeep
Hi @Jaydeep
Download the prebuilt linux binaries from here and test it
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/183304302/2019.2+Release
If you are using SD card boot, just copy BOOT.BIN and image.ub to it and boot to linux
Best Regards
Shabbir
Hello @shabbirk ,
Thanks for quick response & sharing the files. It will be helpful if you can share any PDF tutorial how to test Ethernet module using the prebuilt Linux binaries which you mentioned bellow.
Thanks & Regards
Jaydeep
