Ethernet using internal block memory
I want to design( Microblazed Design) Ethernet 10/100/1000 Mbps using internal Block RAM instead of DDR memory using Vivado 2018.2.
Can you please share me  any reference design files regarding this.
Thanks & Regards,
Prashanth
Re: Ethernet using internal block memory
Hello @prashanth_jagan_491
You might get hints from the posts below.
Example project in microblaze and Ethernet core
https://forums.xilinx.com/t5/Ethernet/Example-project-in-microblaze-and-Ethernet-core/td-p/820482
Yoichi
This forum is based on the cooperation of everyone who participates.
Kindly note - Please mark the Answer as "Accept as solution" if information provided is helpful.
I need a reference design regarding the Ethernet(Without using DDR memory)by using Internal Block RAM  design using MicroBlaze,Please share me reference design files.
Thanks & Regards,
Prashanth.
Yoichi
I think that it is better to remodel with reference to XAPP1026.
Yoichi
Scholar dpaul24
@prashanth_jagan_491,
Did you STUDY and FOLLOW the simulation of the TEMAC example_design from Xilinx?
If yes, then that can be the base design for your internal BRAM + uBlaze based Ethernet design.
In the xilinx example_design, you have a small size rx_fifo after the MAC in which the rx frames are kept. They are later sent out on the MAC tx line. This is what xilinx already gives you, they call it loopback module or something like that. Now modify that design so that loopback FIFO is your BRAM FIFO. You can choose to keep the FIFO size same or increase it, depending on your needs. All the uBlaze system needs to do is read out the frames from this BRAM FIFO.
There isn't any xapp for this.
1. Study the TEMAC frame loopback Xilinx example_design.
2. Study any uBlaze based design such that processor can read from a BRAM FIFO.
3. Use the knowledge learn't from 1. and 2. to design what you want to.
FPGA enthusiast!
All PMs will be ignored
Hello @dpaul24
To the best of my knowledge, there is no such example.
Is the IP Example Design that comes with Vivado helpful?
UG896 Vivado Design Suite User Guide : Designing with IP
Thank you
Yoichi
