FPGA ethernet with MDIO configuration
Hiiiii,
Is there any core available to implement SGMII ethernet interface with MDIO configurtion....?
Re: FPGA ethernet with MDIO configuration
Hi...
I was implemented a ethernet interface with AXI ethernet subsystem instead of using
Tri-mode Ethernet MAC and  SGMII PCS/PMA IP.
MDIO access did with seperate macro.
Thanks for your support
Murali
Voyager
Voyager
There's a Tri-mode Ethernet MAC IP (with MDIO) that supports GbE:
https://www.xilinx.com/products/intellectual-property/temac.html
The MAC could connect to the SGMII PCS/PMA IP:
https://www.xilinx.com/products/intellectual-property/do-di-gmiito1gbsxpcs.html
to interact with a transceiver.
-Joe G.
Hiii,
What about AXI 1G/2.5G Ethernet subsystem IP for my requirment....?
please guide me to implement the interface...
regards
Murali
Hi...
Murali
