ambrown0430
FreeRTOS vs Baremetal
I am working on having an Ethernet interface to offload data from the PL on the Zynq Ultrascale+ MPSoC. I was wondering if there was an advantage using Baremetal or FreeRTOS as the OS when creating the application in Vitis?
Tags (4)
shabbirk
Hi @ambrown0430
I would suggest starting off with the baremetal and is easy to use. /p>
Best Regards
Shabbir
