jogilliam
GTH creation options
I am using vendor IP for an SRIO interface and need the GTH to act as the SerDes.  I am confused because srio_multi_lane is an option for the protocol template but I don't know if this is adding logic that already exists in my vendor IP.  What should the protocol template be if I just want a vanilla SerDes?  Thanks.
venkata
You should be able to find <component_name>_multi_gt and <component_name>_gt files. These are the files to use for updating GT attributes from wizard to IP.
