GTX XLAUI in kintex-7 How Channel Bonding
           I have one more doubt. I am using the XLAUI (4*10Gbps) protocol. I have used example design. I have not seen any channel bonding between the 4 Lanes. How the Four different get landed with correct data in the receiver. Is it possible without the channel bonding between the lanes.
Thanking you
Re: GTX XLAUI in kintex-7 How Channel Bonding
GT does not have channel bonding functionality with protocols using 64B66B encoding. This should be present in fabric design by using the FIFO primitives. Can you please check the IP files for the relevant module?
I assumed your question about  GTX XAUI . The XAUI core will follow the reset sequence described in the GT UG .  With RX data present when the reset is issued synchronization should happen once the CDR lock has occurred.  For Channel bonding though, a gtrxreset is issued if channel bonding is not successful and there could be multiple iterations of this.
Under the right circumstance multiple resets could be needed even if the rx data is valid when  the first reset is issued.  If the buffer  positions end up not aligned across the channels this could  result in channel bonding failing and a gtrxreset being issued.
Thanks and Regards
Balkrishan
Hi Balkrishan
I am using the XLAUI (40 gbps). In this protocol i used the 64B/66B encoding and decoding . I have 4 lanes of each 10Gbps . How the channel bonding will happen between the 4 lanes.
Thanking you
Subash
I am using the example design. In the example there are no FIFO primitives. I think the example have to work around it. In my design i have 4 lanes for Tx and Rx. For the proper alignment of the data between the lanes than i have insert markers between the lanes and check them in the receiver.
Thanking you
