Handle PL 10G link status
Hi all,
I have PL 10G working on ZCU102 based custom board, Vivado/Yocto 2019.1.
In Linux, the 10G interface is up & working. But It can't handle the status changes like fiber disconnected/connected, SFP+ module absent, host interface disabled(disable ethernet interface in PC)/enabled. I tested on
Intel FTLX1471D3BCV-IT and FINISAR ftlx2072d327 + ftlx2072d333 pair.
So my question is, how can I make the Linux os handling 10G link status changes automatically? Thank you.
回复: Handle PL 10G link status
After the fiber disconnected and reconnected, can you do GTRXRESET one more time?
Hello @guozhenp ,
I think GTRXRESET is in FPGA? I'm not FPGA developer, so I have no idea about it :).
Anyway, can PL 10G FPGA IP detect the status changes? or PL 10G Linux driver can handle the status changes detection? Or I have to do it myself via SFP+ I2C command (SFF-8472 standard)?
Does Auto-Negotiation & Link Training feature in PL 10G IP relate to this?
Thank you.
Visitor yubex
which 10G IP are you using?
For example the Xilinx 10G Ethernet Subsystem has a link status register, which you can read.
Hi @yubex and @guozhenp ,
Our FPGA design uses Xilinx 10G/25G Ethernet Subsystem, configuration as attached pictures.
I guess, due to BASE-R mode is used, so Auto-Negotiation & Link Training are disabled, so status registers are mostly empty. (10G IP has base address 0xa0050000):
~# devmem 0xA0050400
0x00000081
~# devmem 0xA0050460
0x00000000
~# devmem 0xA0050464
0x00000000
~# devmem 0xA0050468
0x00000000
~# devmem 0xA0050458
0x00000000
0x00000080
~# devmem 0xA0050404
0x000000E0
~# devmem 0xA0050408
0x00000000
~# devmem 0xA005040c
0x00000001
~# devmem 0xA005043c
0x00000000
~# devmem 0xA0050448
0x00000000
~# devmem 0xA005044c
0x00000000
~# devmem 0xA0050450
0x00000000
~# devmem 0xA0050454
0x00000000
0x00000000
~# devmem 0xA005045c
0x00000000
0x00000000
0x00000000
0x00000000
~# devmem 0xA0050474
0x00000000
~# devmem 0xA0050498
0x00000001
~# devmem 0xA005049c
0x00000000
~# devmem 0xA0050500
0x00000000
I attached the boot log also. For now, the 10G interface doesn't work in U-boot, but it is not my target, so we can ignore u-boot in this topic.
For now, I use static IP on board's 10G interface, 10G PCI card on PC & static IP, PC & board connect directly via fiber cable & SFP+ modules. Everything works fine, except when I reset the 10G interface in PC (reboot the PC, turn off the PC's 10G interface then turn it on by "ifconfig" command) the connection between PC & board will be lost and I have to reset (ifconfig down then up) board's 10G interface to make it works again. That is my problem now.
Thank you for your time & any comments/ideas are appreciated.
Here are 10G configuration in FPGA & boot log. Thanks.
Screenshot from 2019-12-02 08-34-17.pngScreenshot from 2019-12-02 08-34-19.pngScreenshot from 2019-12-02 08-34-22.png
Visitor yubex
according to PG210 page 233, the output "stat_rx_status" of the IP indicates the link status.
Can you use that output, to determine if you have a link or not?
