Hardware time stamping with Xilinx axienet kernel driver and 1G/2.5G AXI Ethernet Subsystem
I'm using Xilinx's linux-xlnx kernel tagged xilinx-v2018.1 to integrate with the 1/2.5G AXI Ethernet Subsystem on a PicoZed SOM and FMCv2 carrier.  My colleagues and I followed this post to add our own RTC core and integrate it with both the subsystem and linux kernel.  The suggestions from that post mirror those from Xilinx's wiki, which states you have to bring your own clock driver to use the subsystem in a 1588 environment (link).
Per that last link, our subsystem is connected in non-processor mode.  What's less clear from that link is if they're indicating that the 1G MAC cannot also use 1588 (it lists both the MAC and as a separate bullet, 1588, but not like the other MACs where the name and 1588 are on the same bullet -- strange).  The 7.1 version of the documentation states that 1588 is supported for both 1 and 2.5G operation (page 6).  I've read their driver source code for the xilinx_axienet_main.c and do not see where the 1G gets singled out vs. the 2.5G.
From all the above, I have to believe it should be possible to use 1588 support on a 1G MAC in Linux.  However, I get a kernel panic when I follow the instructions to enable sync and then start the LinuxPTP daemon (section, 1588 Testing):
[root@host]:# phc2sys -s eth0 -w &
[root@host]:# ptp4l -m -i eth0
ptp4l[100.796]: selected /dev/ptp0 as PTP clock
ptp4l[100.797]: port 1: INITIALIZING to LISTENING on INIT_COMPLETE
ptp4l[100.798]: port 0: INITIALIZING to LISTENING on INIT_COMPLETE
ptp4l[108.234]: port 1: LISTENING to MASTER on ANNOUNCE_RECEIPT_TIMEOUT_EXPIRES
ptp4l[108.235]: selected local clock 000a35.fffe.000000 as best master
ptp4l[108.235]: assuming the grand master role
xilinx_axienet 41000000.ethernet: Did't get FIFO rx interrupt 9437184
Unhandled fault: imprecise external abort (0x1406) at 0x0043aeec
pgd = c0004000
[0043aeec] *pgd=00000000
Internal error: Oops - BUG: 1406 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.14.0-xilinx-v2018.1 #8
Hardware name: Xilinx Zynq Platform
task: c0a06d80 task.stack: c0a00000
PC is at cpuidle_enter_state+0xe4/0x1b4
LR is at cpuidle_enter_state+0xc0/0x1b4
pc : [<c04bb828>]    lr : [<c04bb804>]    psr: 600f0013
sp : c0a01f70  ip : 00000015  fp : 00000000
r10: 00000000  r9 : 00000019  r8 : 6f5fbbaa
r7 : 00000000  r6 : ef7d4340  r5 : 00000019  r4 : 6f642674
r3 : ef7d4e80  r2 : 2ee8f000  r1 : 00000019  r0 : 00000000
Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
Control: 18c5387d  Table: 1fce404a  DAC: 00000051
Process swapper/0 (pid: 0, stack limit = 0xc0a00210)
Stack: (0xc0a01f70 to 0xc0a02000)
1f60:                                     ef7d4340 c0a32b70 00000000 ef7d4340
1f80: c0a32b70 ffffe000 c0a03c68 c0a03cb4 c0933a30 00000000 00000000 c014e0d8
1fa0: 000000be 00000001 ffffffff c0a03c40 efffcd00 c014e270 c0a3ba4c c0900bbc
1fc0: ffffffff ffffffff 00000000 c090066c 00000000 c0933a30 00000000 c0a3bc94
1fe0: c0a03c58 c0933a2c c0a08004 0000406a 413fc090 0000807c 00000000 00000000
[<c04bb828>] (cpuidle_enter_state) from [<c014e0d8>] (do_idle+0x148/0x1a8)
[<c014e0d8>] (do_idle) from [<c014e270>] (cpu_startup_entry+0x18/0x1c)
[<c014e270>] (cpu_startup_entry) from [<c0900bbc>] (start_kernel+0x304/0x364)
Code: f10c0080 e3a00000 ebf2dff3 f1080080 (e0540008)
---[ end trace 9f32ffb8a7d3d425 ]---
Kernel panic - not syncing: Attempted to kill the idle task!
CPU1: stopping
CPU: 1 PID: 0 Comm: swapper/1 Tainted: G      D         4.14.0-xilinx-v2018.1 #8
[<c010e814>] (unwind_backtrace) from [<c010aa30>] (show_stack+0x10/0x14)
[<c010aa30>] (show_stack) from [<c05f0a88>] (dump_stack+0x80/0xa0)
[<c05f0a88>] (dump_stack) from [<c010cf78>] (ipi_cpu_stop+0x3c/0x70)
[<c010cf78>] (ipi_cpu_stop) from [<c010d798>] (handle_IPI+0x64/0x84)
[<c010d798>] (handle_IPI) from [<c0101420>] (gic_handle_irq+0x84/0x90)
[<c0101420>] (gic_handle_irq) from [<c010b48c>] (__irq_svc+0x6c/0xa8)
Exception stack(0xef05ff58 to 0xef05ffa0)
ff40:                                                       00000000 00000019
ff60: 2ee9f000 ef7e4e80 78557396 00000019 ef7e4340 00000000 78010d99 00000019
ff80: 00000000 00000000 00000015 ef05ffa8 c04bb804 c04bb828 60000013 ffffffff
[<c010b48c>] (__irq_svc) from [<c04bb828>] (cpuidle_enter_state+0xe4/0x1b4)
[<c014e270>] (cpu_startup_entry) from [<001016cc>] (0x1016cc)
---[ end Kernel panic - not syncing: Attempted to kill the idle task!
I've added debug logging statements to the transmit ISR (not pictured above) to prove that the ISR does exit successfully.  Moments later though, the above panic occurs.
Has anyone else gone through this exercise before, following that Xilinx Wiki successfully?
We were ultimately able to trace this down to the timestamp FIFO being instantiated without a way to toggle the `tlast` signal.  We added a simple core to do that and were able to stop the kernel panic.  From there, we had to update to the 2018.3 tools and linux kernel in order to get this picozed design working.
For those interested in timing performance relative to Xilinx's wiki, when connected to a boundary clock  that was driven by a grand master hardware clock, the timing converged to an offset RMS of approximately 30 ns.
We're looking forward to also seeing what Xilinx has come up with because it sounds like @jadhavs had a similar set of fixes in mind.
Hi @eengie,
There is a timestamp prerequisite for 1588 mentioned in the wiki page at https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842485/Linux+AXI+Ethernet+driver
Have you tried the flag XILINX_AXI_EMAC_HWTSTAMP enable in the kernel configuration?  In master branch we do have this flag available see at https://github.com/Xilinx/linux-xlnx/blob/master/drivers/net/ethernet/xilinx/Kconfig
So try to enable it and hope you will have then timestamp enabled in 1588 settings.
Hi @amruta.jadhav
Yes, I have that flag enabled as well as patched in drivers for PTP which interfaces with our RTC kernel driver which manages the IP core attached to the system time inputs of the AXI Ethernet Subsystem.
In case it helps in debugging this, I've continued to trace this down and the crash only occurs if ptp4l is running (either configured as grand master or slave).  My test configuration is a separate system with ptp4l configured to be master and the embedded (zynq-based) system as slave.  I've also attempted this all with my kernel revision set to the head of master from last week; it's all the same result.
Thomas
Hi @eengie,
Can you share a kernel panic log to see this issue? Also can you share with us a HDF, XDC & Kconfig details to see how the system is used at your end.
Hi @jadhavs,
The kernel panic log is in the original post and the config is attached (renamed because of the forum rules).  An example HDF and XDC are attached as well
Thomas
Edit 1: Added HDF and XDC.
Based on the kernel documentation, there must be a call to skb_tx_timestamp() as close to the transmission time frame as possible (bullets 1-3) followed by a call to skb_hwtstamp_tx() and freeing the original SKB.  Notably, that skb_hwtstamp_tx() method doesn't exist anywhere in the linux-xlnx kernel source for 2018.1 since it eventually changed to skb_tstamp_tx() (i.e., this is a documentation error).  That method (and the cleanup) are called whether one is using the TSN core or not, so that takes care of bullet 4 (I think).  So to summarize, it looks like the non-TSN use of the xilinx-axienet driver is missing a call to skb_tx_timestamp(), at the very least.
The patch I've attached applies that call approximately where the TSN route would have, and I did verify that line of code is being executed (via dev_info print statement).  However, this does not result in a change; it still kernel panics with a similar stack listing (also attached).
Hi @eengie
I've seen your HDF file and it is built in Vivado 2018.2 s/w version. Have you tried to use Petalinux kernel tagged the same version? (xilinx-v2018.2). We do not support the drivers with downward compatible. With our s/w regression test with 2018.2, we do not see any issue. also the time stamp works as well.
Yes, we're using the kernel tagged xilinx-v2018.2 from https://github.com/xilinx/linux-xlnx.  I realize in an earlier log and post I pointed to the 2018.1, however since then we moved the kernel version to 2018.2 (even though there appeared to be no significant changes to the related driver in a non-TSN configuration like ours).
You say you all are not seeing any such issue -- can you please elaborate on your example design?  Have you all attempted to run ptp4l against that example design?  Any chance you all can post the example design?
[Edits for clarifying the version as well as requesting access to the example design]
We had an odd breakthrough today wherein I added "twoStepFlag 0" to my PTP4L configuration on the target device.  The kernel panic no longer happens; instead it has been replaced with a "timed out while polling for tx timestamp" error and never syncs to the master clock.  I tired increasing the tx_timestamp_timeout to 100 (milliseconds, from the default of 1), but I still get the error.
We noticed that our master clock could only be configured for 2-step mode, so we reconfigured the IP core to 2-step and updated the target.  Interestingly enough, we still get the kernel panic if running in 2-step mode.  If we again set the above twoStepFlag to 0 (to make it 1-step), PTP4L starts and runs without there being a kernel panic (again though, that time out message is present and it does not sync).
Any further suggestions, given the above, @jadhavs?  We have this effort in parallel with trying to use the TSN license (completely separate build, same goal), and neither effort is having much success getting basic 1588 PTPv2.
Hi @eengie
I'll send you our project based on ZC706 board. May be that will help you to resolve this issue.
Do you mind sharing how you toggle the tlast signal? I simply enabled the tlast signal from data width converter. I wouldn't know if the convert would toggle tlast to the fifo? On the S_AXI side of converter, I just fixed the tlast to 1
Sure thing.  Wait until `tvalid` goes low, then toggle `tlast`.  You'll need to delay the data by a clock so it remains in sync.
Thanks for replying. Do you think fixing tlast to 1 would work in this case?
Also, did you connect tx_mac_aclk from 1G/2.5G AXI Ethernet Subsystem to your datawidth converter's aclk? If yes, what kind of reset signal did you use? I couldn't find a reset signal to it.
Yes, make a processor system reset for the tx_max_aclk and use the interconnect reset.  That reset should only be used for the s_axis reset_n on the axis clock converter though.
I've been told that Xilinx has a fix for this design (in general); we're waiting for it to arrive so that we can compare notes and test it so that hopefully it makes it into the next tooling release so we can drop these little custom tweaks.
Hi I did put in the proc sys reset ip but I used the peripheral_reset (for both clock converter and datawidth converter) before I saw your reply. Did you feed any thing to ext_reset_in? I feed it with pma_reset_out from ethernet subsystem. No reason, it is just I don't have anything to feed to it.
I am testing my design and it did make the panic go away. But weird thing is that ptp master never replied Delay Response Message to my Delay Request Message. I was building the whole thing from 20181. I remember you said you have to upgrade linux to 20183 for this to work. So after you make panic go away, what kind of problem made you switch to 20183?
Interesting.  We didn't see that behavior, but we did see squirrely acknowledgements of the foreign master and then ignoring it.  This was caused by the firewall still being up and blocking the PTP traffic.
That reset we drove from the PS.
What prompted the jump to 2018.3 was that after a considerable amount of time debugging, we progressively ended up at 2018.3 around the time that Xilinx told us their fix would be easier if we could be in 2018.3 as well.
