tkolcak
Help for GT Ref Clk of 10G/25G Eth Subsystem Design
When using this IP both in board flow (investigating an O-RAN example design for ZCU11) and device flow (when I created a blank design for a device with GTY), I cannot see 390.625 as GT Ref clk option when IP is configured with below options:
Core: Ethernet MAC + PCS/PMA 64 bit
Speed : 25.87125G
GT Ref Clk that is presented on IP UI is 156.25 (and some other values starting from  161.13.. to 322.26)
Per user guide pg210, I was expecting IP will use a 390.625 MHz refclk for 25G operation. What is the reason for this difference and could anyone help me to understand the requirement of GT Ref Clk for 25G MAC + PCS/PMA operation ?
Tags (3)
guozhenp
In PG210, 390MHz refer to core clock, not GT Ref Clk.
PG210 also has Table299 to show the available GT Ref Clk for 10G/25G IP core. There's no 390MHz at the moment.
guozhenp
tkolcak
Thank you @guozhenp
