How can I find the read (receive) and write (transmit) functions in lwip echo server project
I am working on Ethernet lwip echo server using zcu102 evaluation board. I am unable to identify write and read functions in this example. Can any one support where those functions available to send custom data using write function.
Best Regards,
Harinath.
nishak
harinatha.reddy@eldaas.com,
Pls. check the following document. It explains the read and write calls used with different lwip applications.
https://www.xilinx.com/support/documentation/application_notes/xapp1026.pdf
/Nisha
Thank you for your response,
i already checked that application note, in echo server loop back example code i am not getting where it is reading and how it is sending same data. please support an provide any proven codes you are having.
nishak
As mentioned in the document, in tcp layer, when a packet is received recv callback function will be called. tcp_recved indcates that packet has been received. and the same data is written back using tcp_write function.
To know more about read and write at tcp layer, check tcp_in.c and tcp_out.c. the calls in these functions call/called by IP layer. Those can be found under ip4.c.
IP APIs in turn call/called by xemacpsif.c low level input and output calls. I hope this helps.
/Nisha
Thank you for your information,
I understood packet receive and send back functions, but inside structure i am unable to get.
tcp_recved(tpcb, p->len); this is for receiving packet, here in tpcb it is receiving or in p->len that i am not getting.
err = tcp_write(tpcb, p->payload, p->len, 1); this is for sending packet, here tpcb it is sending or p->payload it is sending that i am not getting.
I want to send my own data using tcp_write function, how i want to send that i am not getting.
Kindly help and provide solution.
Thank you.
